Question / Help encoder overload on abs
mp91
Hello Guys, I´m new here.
First of all sorry for my bad English.
I started a job and need to use my MacBook Air from 2017 for streaming. I install obs 25.0.8 on my MacBook.
In my first streaming I had the encoder overload problem. CPU was at 40% FPS on 23.
How can I fix this problem? Can somebody please help me?
thank you very much
thank you very much
what are you trying to stream? whats the video quality of the input and what are you trying to output is as?
i´m trying to stream a website that I use for Trading analysis on streaming platform Vimeo.
FPS is on 30 and then 1920x1080.
Is that what you want to know?
Set your canvas to 1280x720
use display capture to get the website. Window Capture is not as smooth. I included a screen capture to show you how you can isolate it to a firefox window. You still need to crop to get the window title out of the stream.
If you disable the preview in OBS that saves you some computational power. I hope it works out
what did you mean with crop? because I don´t have this in my window for monitor capturing
These are my settings and yes i capture my screen
Hello , everything works fine with 1280x720 and i wanted to ask if it’s possibile to stream with 1920x1080??
