Droidcam lagging and Glitching at High resolutions
maksud akuli
Hi OBS team,
I am using OBS Studio on a Windows laptop with DroidCam as a video source and routing audio directly from a mixer for live streams (1920x1080, 4000 kbps). However, when running at higher resolutions, the DroidCam video lags and glitches.
Here is what I have noticed and tried so far:
- Lag/glitching happens mainly at higher resolution settings.
- I have checked my connection and tried restarting the app/source.
Could you help me figure out how to get smooth video without lag or glitching? Here are my setup details:
- OS: Windows
- OBS Studio version: [Insert OBS version]
- DroidCam client/app version: [Insert DroidCam version]
- Connection type (USB or Wi-Fi): [Insert USB/Wi-Fi]
Thanks in advance for your help!
Does the camera already stutter in the OBS preview before you start streaming? If it does, leave the stream at 1080p and try just the DroidCam source at 720p30. Are you connecting the phone over USB or Wi-Fi?
Droidcam isn't part of OBS.
If you have issues with a third party plugin you should contact its dev (and other users) via the Discussion section on the particular plugins' page or wherever the dev have set for this.
