Question / Help Desktop-Audio can't be enabled
Pervasive030
Hi there,
I want to stream some live DJ sets with twitch using the OBS broadcast.
So I tried to setup an "Audio Output Capture" and connect my DJ controller.
OBS can't detect this device unfortunately.
Then I tried to enable Desktop-Audio so I can stream my desktop with the audio from the DJ software.
But there is just no "enable" option in the audio settings to choose :(
I can only choose "disabled".
I looked up everything, but all audio related problems that are described are not related to that simple setting.
I'm using a mac book pro 2015 / high sierra version 10.13.6
Thank you in advance!
Toni
