Question / Help Crashes After Installing Video Capture , PLEASE HELP
Mr.GxXXx
I need help with obs studio because its crashing as soon as I try to add my cam or el gato (video capture device's) , I uninstalled and reinstalled still the same . Here's the log file . Please help me !
  • 2016-07-04 11-55-29.txt
  • 2016-07-04 11-54-17.txt
I suspect it's either the cam or the elgato causing the problem. Try with one or the other unplugged.
Then you likely still have a webcam-like device connected that is causing the problem.
If you don't you may need to uninstall and reinstall the software for your webcam AND your elgato.
