Question / Help crash on opening
I'd try either getting rid of your ~/Applications Supports/obs-studio folder and if that doesn't work, downgrading to the previous OSX patch.
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /usr/local/opt/qt5/lib/QtWidgets.framework/Versions/5/QtWidgets
Referenced from: /Volumes/VOLUME/*/OBS.app/Contents/Resources/bin/obs
Reason: image not found
Binary Images:
0x103e73000 - 0x103fb9fff +obs (0) <18D56626-B45C-3079-AF6B-7DB0118E16B9> /var/folders/*/OBS.app/Contents/Resources/bin/obs
0x10a278000 - 0x10a2b5267 dyld (421.2) <947FC440-80F9-32F7-A773-6FC418FE1AB7> /usr/lib/dyld
Model: iMac13,2, BootROM IM131.010A.B0A, 4 processors, Intel Core i5, 2.9 GHz, 8 GB, SMC 2.11f14
Graphics: NVIDIA GeForce GTX 660M, NVIDIA GeForce GTX 660M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3431554638424455352D474E2D4620
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x02FE, 0x45424A3431554638424455352D474E2D4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF4), Broadcom BCM43xx 1.0 (7.21.171.68.1a5)
Bluetooth: Version 5.0.3f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: APPLE HDD ST1000DM003, 1 TB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
USB Device: HD Pro Webcam C920
USB Device: Game Capture HD
Thunderbolt Bus: iMac, Apple Inc., 23.4
Here is what I see and nothing works
Process: obs [1222]
Path: /Applications/OBS.app/Contents/Resources/bin/obs
Identifier: com.obsproject.obs-studio
Version: 0.16.2 (0.16.2)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: obs [1222]
User ID: 501
Date/Time: 2017-03-03 16:49:10.049 +0900
OS Version: Mac OS X 10.12.3 (16D32)
Report Version: 12
Anonymous UUID: 99082409-4F6F-6BB2-17FB-55BB076F2A47
Time Awake Since Boot: 2300 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000016
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0x16:
__TEXT 0000000101951000-0000000101aa3000 [ 1352K] r-x/rwx SM=COW /Applications/OBS.app/Contents/Resources/bin/obs
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_platform.dylib 0x00007fffe961b313 _platform_strcmp + 19
1 libobs.0.dylib 0x000000010482466b signal_handler_disconnect + 91
2 obs 0x0000000101a25ddc VisibilityItemWidget::~VisibilityItemWidget() + 76
3 obs 0x0000000101a260fe VisibilityItemWidget::~VisibilityItemWidget() + 14
4 obs 0x0000000101a24744 DeleteListItem(QListWidget*, QListWidgetItem*) + 36
5 obs 0x0000000101973796 OBSBasic::RemoveSceneItem(OBSRef<obs_scene_item*, &(obs_sceneitem_addref), &(obs_sceneitem_release)>) + 230
6 obs 0x0000000101a2fa79 OBSBasic::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 905
7 QtCore 0x00000001044642d2 QMetaMethod::invoke(QObject*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) const + 1026
8 QtCore 0x00000001044638fa QMetaObject::invokeMethod(QObject*, char const*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) + 2122
9 obs 0x0000000101972b1f OBSBasic::SceneItemRemoved(void*, calldata*) + 367
10 libobs.0.dylib 0x00000001048247e6 signal_handler_signal + 182
11 libobs.0.dylib 0x000000010489847f remove_all_items + 399
12 libobs.0.dylib 0x0000000104893d3e scene_destroy + 14
13 libobs.0.dylib 0x000000010485fffa obs_source_destroy + 698
14 libobs.0.dylib 0x0000000104872465 obs_shutdown + 1669
15 obs 0x000000010195cf88 OBSApp::~OBSApp() + 280
16 obs 0x000000010196034b main + 4523
17 libdyld.dylib 0x00007fffe940e255 start + 1
Thread 1:: CEF Isolation IO Thread
0 libsystem_kernel.dylib 0x00007fffe953538a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fffe95347d7 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fffd3e12e84 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fffd3e12301 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fffd3e11b54 CFRunLoopRunSpecific + 420
5 com.apple.Foundation 0x00007fffd5844612 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277
6 obs-browser.so 0x000000010d23503a -[ClientConnectionDelegate createConnectionThread] + 378
7 com.apple.Foundation 0x00007fffd5854c6d __NSThread__start__ + 1243
8 libsystem_pthread.dylib 0x00007fffe9625aab _pthread_body + 180
9 libsystem_pthread.dylib 0x00007fffe96259f7 _pthread_start + 286
10 libsystem_pthread.dylib 0x00007fffe96251fd thread_start + 13
Thread 2:
0 libsystem_pthread.dylib 0x00007fffe96251e0 start_wqthread + 0
Thread 3:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x00007fffd399af26 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 122
3 com.apple.audio.CoreAudio 0x00007fffd399ae9c HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4 com.apple.audio.CoreAudio 0x00007fffd3997cee HALC_ProxyIOContext::IOWorkLoop() + 1198
5 com.apple.audio.CoreAudio 0x00007fffd3997667 HALC_ProxyIOContext::IOThreadEntry(void*) + 131
6 com.apple.audio.CoreAudio 0x00007fffd399738b HALB_IOThread::Entry(void*) + 75
7 libsystem_pthread.dylib 0x00007fffe9625aab _pthread_body + 180
8 libsystem_pthread.dylib 0x00007fffe96259f7 _pthread_start + 286
9 libsystem_pthread.dylib 0x00007fffe96251fd thread_start + 13
Thread 4:: com.apple.audio.IOThread.client
Thread 5:
0 libsystem_kernel.dylib 0x00007fffe953cc86 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fffe962696a _pthread_cond_wait + 712
2 libobs.0.dylib 0x0000000104857170 os_event_wait + 32
3 mac-capture.so 0x000000010b251eb4 capture_thread + 36
4 libsystem_pthread.dylib 0x00007fffe9625aab _pthread_body + 180
5 libsystem_pthread.dylib 0x00007fffe96259f7 _pthread_start + 286
6 libsystem_pthread.dylib 0x00007fffe96251fd thread_start + 13
Thread 6:
Thread 7:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fffd1a8fa62 _NSEventThread + 205
6 libsystem_pthread.dylib 0x00007fffe9625aab _pthread_body + 180
7 libsystem_pthread.dylib 0x00007fffe96259f7 _pthread_start + 286
8 libsystem_pthread.dylib 0x00007fffe96251fd thread_start + 13
Thread 8:
1 ??? 0x0000000105f1be00 0 + 4394696192
Thread 9:
0 libsystem_kernel.dylib 0x00007fffe953d4e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fffe9625791 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007fffe96251ed start_wqthread + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007f85df171360 rcx: 0x0000000000000000 rdx: 0x0000000101a253e0
rdi: 0x0000000000000016 rsi: 0x0000000101a87462 rbp: 0x00007fff5e2ad3c0 rsp: 0x00007fff5e2ad3c0
r8: 0x0000000000000040 r9: 0x00007f85df16a598 r10: 0xffffffffffffffff r11: 0x0000000000012068
r12: 0x0000000101a253e0 r13: 0x00007f85df16f460 r14: 0x0000000101a87462 r15: 0x00007f85df16f468
rip: 0x00007fffe961b313 rfl: 0x0000000000010206 cr2: 0x0000000000000016
Logical CPU: 1
Error Code: 0x00000004
Trap Number: 14
here is my latest log
16:57:53.610: CPU Name: Intel(R) Core(TM) i5-3470S CPU @ 2.90GHz
16:57:53.610: CPU Speed: 2900MHz
16:57:53.610: Physical Cores: 4, Logical Cores: 4
16:57:53.610: Physical Memory: 8192MB Total
16:57:53.610: OS Name: Mac OS X (NSMACHOperatingSystem)
16:57:53.611: OS Version: Version 10.12.3 (Build 16D32)
16:57:53.611: Kernel Version: 16.4.0
16:57:53.615: hotkeys-cocoa: Using layout 'com.apple.keylayout.US'
16:57:53.653: OBS 0.16.2 (mac)
16:57:53.653: ---------------------------------
16:57:53.653: audio settings reset:
16:57:53.653: samples per sec: 44100
16:57:53.653: speakers: 2
16:57:53.729: ---------------------------------
16:57:53.729: video settings reset:
16:57:53.729: base resolution: 2560x1440
16:57:53.729: output resolution: 1280x720
16:57:53.729: downscale filter: Bicubic
16:57:53.729: fps: 30/1
16:57:53.729: format: NV12
16:57:53.742: No blackmagic support
16:57:53.767: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
16:57:53.772: os_dlopen(../obs-plugins/obs-libfdk.so->../obs-plugins/obs-libfdk.so): dlopen(../obs-plugins/obs-libfdk.so, 1): Library not loaded: /usr/local/opt/fdk-aac/lib/libfdk-aac.1.dylib
16:57:53.772: Referenced from: /Applications/OBS.app/Contents/Resources/obs-plugins/obs-libfdk.so
16:57:53.772: Reason: image not found
16:57:53.772:
16:57:53.772: Module '../obs-plugins/obs-libfdk.so' not found
16:57:53.776: os_dlopen(../obs-plugins/obs-vst.so->../obs-plugins/obs-vst.so): dlopen(../obs-plugins/obs-vst.so, 1): Library not loaded: /usr/local/opt/qt5/lib/QtWidgets.framework/Versions/5/QtWidgets
16:57:53.776: Referenced from: /Applications/OBS.app/Contents/Resources/obs-plugins/obs-vst.so
16:57:53.776: Reason: image not found
16:57:53.776:
16:57:53.776: Module '../obs-plugins/obs-vst.so' not found
16:57:53.785: os_dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlc.5.dylib->/Applications/VLC.app/Contents/MacOS/lib/libvlc.5.dylib): dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlc.5.dylib, 1): image not found
16:57:53.785:
16:57:53.785: Couldn't find VLC installation, VLC video source disabled
16:57:53.787: Failed to load 'en-US' text for module: 'obs-browser.so'
16:57:53.787: [browser_source: 'Version: 1.25.0']
16:57:53.787: ---------------------------------
16:57:53.787: Loaded Modules:
16:57:53.787: obs-browser.so
16:57:53.787: vlc-video.so
16:57:53.787: text-freetype2.so
16:57:53.787: rtmp-services.so
16:57:53.787: obs-x264.so
16:57:53.787: obs-transitions.so
16:57:53.787: obs-outputs.so
16:57:53.787: obs-filters.so
16:57:53.787: obs-ffmpeg.so
16:57:53.787: mac-vth264.so
16:57:53.787: mac-syphon.so
16:57:53.787: mac-decklink.so
16:57:53.787: mac-capture.so
16:57:53.787: mac-avcapture.so
16:57:53.787: image-source.so
16:57:53.787: frontend-tools.so
16:57:53.787: coreaudio-encoder.so
16:57:53.787: ==== Startup complete ===============================================
16:57:53.802: Service '' not found
16:57:53.803: Switched to Preview/Program mode
16:57:53.803: ------------------------------------------------
16:57:53.805: All scene data cleared
16:57:53.805: ------------------------------------------------
16:57:53.875: coreaudio: device 'Soundflower (2ch)' initialized
16:57:53.878: coreaudio: device 'HD Pro Webcam C920' initialized
16:57:54.109: Switched to scene 'Destiny'
16:57:54.266: ------------------------------------------------
16:57:54.266: Loaded scenes:
16:57:54.266: - scene 'Destiny':
16:57:54.266: - source: 'Elgato HD60 Desinty' (display_capture)
16:57:54.266: - source: 'Window Capture Elgato' (window_capture)
16:57:54.266: - source: 'Donation' (browser_source)
16:57:54.266: - source: 'Tip Jar' (browser_source)
16:57:54.266: - source: 'Alerts' (browser_source)
16:57:54.266: - source: 'Overlay1' (image_source)
16:57:54.266: - source: 'Camera Overlay' (image_source)
16:57:54.266: - source: 'newfollower ticker' (text_ft2_source)
16:57:54.266: - filter: 'Scroll' (scroll_filter)
16:57:54.266: - source: 'New Follower' (text_ft2_source)
16:57:54.266: - source: 'Top Donator Ticker' (text_ft2_source)
16:57:54.266: - source: 'Top Donator' (text_ft2_source)
16:57:54.266: - source: 'Chat Box' (browser_source)
16:57:54.266: - source: 'Inremission Scene' (window_capture)
16:57:54.266: - source: 'Intermission' (image_source)
16:57:54.266: - source: 'Offline' (image_source)
16:57:54.266: - filter: 'Sharpen' (sharpness_filter)
16:57:54.266: - scene 'Game Intermission':
16:57:54.284: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
16:57:54.644: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
16:57:54.667: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
16:57:54.690: adding 23 milliseconds of audio buffering, total audio buffering is now 92 milliseconds
16:57:54.714: adding 23 milliseconds of audio buffering, total audio buffering is now 116 milliseconds
16:57:54.737: adding 23 milliseconds of audio buffering, total audio buffering is now 139 milliseconds
16:57:54.760: adding 23 milliseconds of audio buffering, total audio buffering is now 162 milliseconds
16:57:54.788: adding 23 milliseconds of audio buffering, total audio buffering is now 185 milliseconds
16:57:54.814: adding 23 milliseconds of audio buffering, total audio buffering is now 208 milliseconds
16:57:54.814: adding 23 milliseconds of audio buffering, total audio buffering is now 232 milliseconds
16:57:54.838: adding 23 milliseconds of audio buffering, total audio buffering is now 255 milliseconds
16:57:54.862: adding 23 milliseconds of audio buffering, total audio buffering is now 278 milliseconds
16:57:54.886: adding 23 milliseconds of audio buffering, total audio buffering is now 301 milliseconds
16:57:54.912: adding 23 milliseconds of audio buffering, total audio buffering is now 325 milliseconds
16:57:54.936: adding 23 milliseconds of audio buffering, total audio buffering is now 348 milliseconds
16:57:54.962: adding 23 milliseconds of audio buffering, total audio buffering is now 371 milliseconds
16:57:54.990: adding 23 milliseconds of audio buffering, total audio buffering is now 394 milliseconds
16:57:55.016: adding 23 milliseconds of audio buffering, total audio buffering is now 417 milliseconds
16:57:55.041: adding 23 milliseconds of audio buffering, total audio buffering is now 441 milliseconds
16:57:55.064: adding 23 milliseconds of audio buffering, total audio buffering is now 464 milliseconds
16:57:55.087: adding 23 milliseconds of audio buffering, total audio buffering is now 487 milliseconds
16:57:55.112: adding 23 milliseconds of audio buffering, total audio buffering is now 510 milliseconds
16:57:55.136: adding 23 milliseconds of audio buffering, total audio buffering is now 534 milliseconds
16:57:55.160: adding 23 milliseconds of audio buffering, total audio buffering is now 557 milliseconds
16:57:55.184: adding 23 milliseconds of audio buffering, total audio buffering is now 580 milliseconds
16:57:55.209: adding 23 milliseconds of audio buffering, total audio buffering is now 603 milliseconds
16:57:55.235: adding 23 milliseconds of audio buffering, total audio buffering is now 626 milliseconds
16:57:55.236: adding 23 milliseconds of audio buffering, total audio buffering is now 650 milliseconds
16:57:55.260: adding 23 milliseconds of audio buffering, total audio buffering is now 673 milliseconds
16:57:55.283: adding 23 milliseconds of audio buffering, total audio buffering is now 696 milliseconds
16:57:55.311: adding 23 milliseconds of audio buffering, total audio buffering is now 719 milliseconds
16:57:55.640: Last log entry repeated for 13 more lines
16:57:55.641: Max audio buffering reached!
16:57:55.641: adding 23 milliseconds of audio buffering, total audio buffering is now 1044 milliseconds
