Question / Help CPU preset for recording?
Ubertwink
I am using Custom output for recording and I can't find the setting for CPU preset.
If I switch output to Standard and encoder to "Use stream encoder", it hooks one from the streaming tab, but with Custom output it is always "veryfast".
How can I change it?
You don't need to do that to set a different bitrate OR preset.
In fact, you don't even need to use advanced output mode.
Simple output mode
Indistinguishable recording quality
software low cpu use or hardware encoder.
