capture quality
gringo92cba
good night,
I have been trying different settings to record with my Elgato HD60X capture device from the Nintendo Switch, but the result is always bad, the colors look dull and the video quality is not good, and it ends up being a maximum of 720p.
Could you help me correctly configure the application to record?
thank you
1. Switch Video Output: Up to 1920x1080 pixels, 60 fps in TV Mode, output is via the HDMI cable. When in Tabletop or Handheld Mode, the maximum video output resolution is 1280x720 pixels in line with the screen resolution.
2. See the attached image from HD60X settings I use on PS4.
3. Your OBS advanced video settings should match. format NV12, space 709, range limited. No HDR on Switch.
If still having issues then
Look into mClassic for "better" color, anti-aliasing and up-scaling or something similar. *I have no experience with that on Switch, PS4 only and streaming sticks.
Literally perfect! I've been trying to correct this forever, TY!
