Question / Help BSOD while streaming.
Itsnelis
Hello, so im streaming a while now and never had issues while streaming. So one day i was streaming and after a couple of minutes i had a BSOD. So i waited for it restard and wanted continue streaming. But when i tried i kept having BSOD. Could someone help me with this problem ASAP?
Nils.
Download BlueScreenView from NirSoft and it will tell you what caused the BSOD.
well these are the results hope you can help me further with it.
Bad CPU Overclock or Undervolt, bad RAM OC, UV (like XMP Profile) if you ever touched anything in the BIOS there most likely lies the Problem.
I personally seem to have undervolted my CPU to much which caused BSOD and the XMP Profile was not Stable (since OC is never Guaranteed to be stable no matter what the Box says), which caused Games to Crash.
but i don´t know if anything is OC. how do i find that?
i buyed it from someone who build it yes.
So you have to ask him if he did any OC of the device or go into the BIOS yourself.
CPU, RAM (especially XMP Profiles, he should know what I mean), GPU
Be prepared to do a lot of reading since every BIOS looks different. Or invite that someone to help you, since it is most likely an OC Problem and has nothing to do with OBS from what I saw in the Pictures.
i got then another problem. The part where you are able to get into the BIOS when booting up hah? Yeh my pc skips that part and it won´t let me open the BIOS.
So the dude that set up your PC activated Fast Boot in the BIOS xD which skips that screen. Wow, what a ****.
I have no Idea how to get into the BIOS when that is active. You would need the Mainboard Manual for that or Google.
Well my keyboard just doesn´t work when starting the PC. It´s an RGB keyboard and when i touch it it normally brights up. But when booting up it doesn´t.
