Browser Source Alpha Issue
PetitJabanes
Hi everyone,
Since v27, I've been having some issues with my overlays (see image bellow) :
The logo on the left and text on the right are from a browser source (one is an SVG and the other just plain text), both set to "rgba(255, 255, 255, 0.5)" but as you can see, they appear darker than what they used to in V26, darker than the white rectangle (a color source with its opacity set to 50%) I've put there for comparison.
I understand there is probably a link with the new way OBS is handling color blending but I have no idea on how to solve this. Everything blends correctly when using the opacity setting in OBS (if I use a PNG version of the logo for example and set its opacity to 50%) but it looks like the alpha from a browser source is mixed with a (hypothetic) black background before setting the alpha to its correct value. Does it make sens?
Found the solution:
Right click the source -> Blending Method -> SRGB Off
(OBS v32)
