Bible Dock Plugin 0.9
manoliszzz
manoliszzz submitted a new resource:
Bible Dock Plugin - The Bible Dock Plugin is a free and customizable tool designed for use with OBS Studio.
Summary​
The Bible Dock Plugin is a free and customizable tool designed for use with OBS Studio. It allows users to seamlessly integrate Bible text, chapter navigation, and verse selection into their live streams or presentations. The plugin offers a variety of features that enhance the display and control of Bible verses during presentations, making it suitable for both full-screen and partial display views.
The plugin consists of several components:
Hi Manoliszzz,
Awesome plugin. Many thanks for posting this plugin for use in church service. Well done for your hard work.
I have been looking for a plugin as this. so I tested the sample links as provided by you and it works well with on internet connection. The challenge is that an internet connection is needed to used the sample links you provided and Internet connection is no always available, so please can you assist to explain how this can be configured to be used offline i.e. without the need for an internet connection with all files hosted on our laptop or PC. Please can you also help describe how to download and correctly configure all the required html , txt and other files in such a way that they can actually function correctly offline based on files hosted on our laptop or PC.
Once again well done for your hard work. Hoping to get your kind feedback.
Hi Manoliszzz,
Hello, sorry for the delay, I think it is better to find a tech to help you. Installation is easy for techs. I could help you in case you would like to get a compatible Bible version. Manolis
Hey Manolis, anyway you could condense/combine the pages? I really like this one but I feel like it could be a bit more screen friendly by combining the Books and Chapters with Verses and References. Also the Chapter Page Variables doesn't need its own page. Maybe use drop down menus and use the OSB Standard Theme. This would make the setup easier and give it a more user friendly interface.
- Carson
