Better Screenshot Plugin
Better Screenshot Plugin 1.3.0
MMLTech
Member
MMLTech submitted a new resource:
Better Screenshot Plugin - Better Screenshot a simple plugin that makes taking and sharing screenshots way easier.
Better Screenshot for OBS Studio is a simple plugin that makes taking and sharing screenshots way easier.
Instead of saving huge PNG files like OBS normally does, it lets you use JPG or WebP to keep file sizes much smaller without losing noticeable quality.
You can:
  • Take screenshots with a custom hotkey
  • Choose the format and quality
  • Save them to a specific folder
  • Automatically send...
MMLTech updated Better Screenshot Plugin with a new update entry:
Hotfixes
  • Rapid screenshots are now serialized, preventing re-entrant captures from overwriting shared screenshot state.
  • Original OBS images are deleted asynchronously after a short delay, with up to eight retries.
  • Cleanup failures are logged instead of showing misleading errors after the converted screenshot was already saved.
  • Qt TLS plugin paths are configured only when a valid HTTPS Discord webhook is actually used.
  • Missing qschannelbackend.dll no longer affects packaging or...
If you mainly need cleaner screenshots, I’d check whether the plugin can capture the source at its native resolution rather than relying on the preview. Also worth looking at OBS’s built-in screenshot options first - you may not need a separate plugin unless you need specific formats or automation.
The plugin uses the built-in screenshot feature, it takes the PNG format, optimizes it, and then deletes the original PNG if the option to remove it is selected. As of now, the native screenshot feature in OBS does not allow you to select the output extension. Plus, this plugin offers the option to send the screenshot directly to your Discord server via a webhook. Because the plugin itself cannot capture a frame from the currently rendered view, I decided to take the original screenshot and convert it instead.
thank you for the plugin! works as advertised and the jpg quality is superb!
two suggestions for the plugin:
- also send screenshot to clipboard (would be very handy for editing and sharing purposes)
- rename screenshot
Version 1.3.0 Release - Compatibility for OBS Studio 33.0.0
  • Needs OBS Studio 33 or newer. On OBS 31/32 keep using 1.2.3.
  • New install folder: unzip into C:\ProgramData\obs-studio\plugins\ (not obs-plugins\64bit anymore). Delete the old copy from Program Files.
  • Screenshots are faster and OBS no longer freezes for a moment while taking one.
  • OBS no longer creates an extra PNG first, so the "Delete original image" option is gone.
  • New quality slider for JPG and WebP.
  • New option to copy the screenshot to the clipboard.
  • New option...
Hi, I've been using this plugin for a few months and it's a game changer. The problem is it no longer works. The plugin page on this forum links to a weird website https://streamrsc.com/better-screenshot-obs-screenshot-plugin-with-discord-upload that doesn't have a download. It only has a link to Github that has older versions. How do we download the current version of Better Screenshot?
That website is my resources portfolio the plugin was always downloaded from there and the latest version is 1.3.0 is exclusively for OBS v33+ if you want to use it in OBS v32+ scroll down the github releases and download the previous version v1.2.3
I'm using OBS 33 so I need the latest version of your plugin. It's not available to download on StreamRSC. There is just a link to the same Github with older versions
That download on github redirects you to the latest version , scroll down to the packages make sure you expand the Assets.
