Audio Stems Recorder
Audio Stems Recorder 2.0.0
MMLTech
Member
MMLTech submitted a new resource:
Audio Stems Recorder - Record every audio source in your stream as its own professional audio layer.
Audio Stems Recorder for OBS Studio
Record every audio source in your stream as its own high-quality WAV file.
This plugin automatically captures each selected OBS audio source separately whenever you start or stop Recording or Streaming. Instead of one mixed track, you get clean, perfectly synced audio stems for professional editing.
Key Features:
• Per-source WAV recording (Mic, Game...
MMLTech updated Audio Stems Recorder with a new update entry:
Added configurable output settings
The audio export pipeline was refactored to introduce a centralized stems::export_audio(...) function, enabling a unified post-processing stage for all recorded stems. Recording now captures raw PCM data while final output generation is handled separately through a format-aware transcode layer. Support was added for selectable output formats (WAV and MP3), with WAV using PCM encoding and MP3 using bitrate-based compression. The system now derives audio parameters such as sample rate, channel...
Once again, you came through MMLTECH! Easy install on Mac! Thank You!
Thank you so much for the feedback :D this new version has brought a lot of major changes and fixed a issue that I was dealing with for a long time, whenever you stoped a recording it was causing a lot of lag to render the audio, now it processes it on the fly and it should not cause crashes anymore.
