atkAudio Plugin
atkAudio Plugin 0.36.2
I found a Plug in Manager. But I don't see the items you mentioned.
That interface wasn't showing while the system was working. I had to copy over the newer version. I did get it to rescan and become functional in OBS, but other audio programs, even after rescanning plugins, can't load or use the Riverflux plugins anymore. Also, the metering seems to only update once a second in OBS with the new version of the plug in. I see no benefits to the updated version. Only causing issues, so going back to the earlier version.
Looks like going back to the old version didn't work this time, even after rescanning plugins.
Now I'm screwed.
I ended up running the 0.4.3 setup program again to do a complete reinstall of the plugins. Apparently copying a backup of the VST3 folders didn't fix it. The 0.4.7 version seems incompatible with Audacity 4.0, although it worked in OBS. Since there's no benefit to the newer version, I'll stick with the older version for now, where everything works.
Now I'm screwed.
with PluginHost, you should be able to get Relic working if you 1) remove/uninstall the Relic plugins from your VST3 folder(s), 2) then from Options... select "Remove any plug-ins whose files no longer exist" 3) install new versions of Relic 4) from Options... Scan for new or updated VST3 plug-ins.
I was indeed able to get the new Relic plugins to work with OBS, but he problem was other programs, despite rescanning for plugins and showing all good, could not load the newer plugins. The older version works fine, Anyway, if it ain't broke....
ah, ok. Other programs might also need somekind of refresh coreography too, but that's just a guess.
I thought it was odd that Audacity 4.0 refused to load the plugins while it's plug in manager gave "ok" across the board after refreshing the list on startup. I reinstalled the earlier version and everyone's happy now.
waves rcompressor takes input and output but its settings do not affect the audio and no gain reduction is happening even with threshold all the way down
. This is the only plugin that i am having issue with
You need to connect something to that RComp node sidechain bus inputs (e.g. from same source as main bus). Or right click -> Configure Audio I/O and disable the sidechain input bus. Some plugins offer explicit control over this in their interface, and some, like RCompressor apparently, implicitly expect signal on sidechain bus if the bus is enabled.
