Asynchronous Audio Filter 0.6.0
Thank you for the plugin, it works.
I am using Presonus Revelator IO24 audio interface.
Before applying the filter, I noticed that each dropout is about 50 to 60ms. After applying the filter, the dropout is shortened to 20 to 30 ms each.
My guess is that for my case, the clock drift difference is too big that 1 added audio packet is not quite sufficient to correct the dropout.
Since there is NO settings to increase the number of added packet, will applying 2 async filters in series help ?
Thank you for making this. You have no idea how long I tried to find a solution to my mic randomly "popping" in OBS. I thought I tried everything: I swapped out XLR cables, I tried two different mics, I made sure my audio interface was set to 48khz just like OBS. . nothing worked. I knew it had something to do with either my audio interface or the XLR input because the popping did not occur when using the same mics in USB mode.
After doing a bit of additional research I eventually found out that audio popping in OBS when using an audio interface is apparently a common problem on Macs and it's cause is this drift between the interface's internal clock and the system clock. I came across this plugin during my search and decided to give it a try. It works perfectly. I put it at the beginning of my filter chain for my mic and all of those intermittent pops are gone. I'm not sure why this drift isn't accounted for in some way by OBS already but thank you for coming up with a solution to it.
