Ashmanix Countdown Timer
Hi, have you removed the plugin files in the old location? It might be detecting both sets of files?
Yes. My current file locations (portable OBS install):
Hi, I'm also running a fresh portable OBS Install and had a similar issue in the plugin not being recognised for the new plugin directory for OBS 33+, however I have just resolved it and would like to show what I did.
Firstly, the new plugin directory is like so:
However when I tried running OBS, it wouldn't recognise the plugin at all, it was also not displaying in the Plugin Manager, all the other plugins listed function as intended in this directory.
What I have noticed is that the rest of the plugins have their bin files as shown here for example:
So I moved the files (cut-pasted) in the bin folder as shown here (the bin folder is empty now):
After moving the bin files here, the plugin now works as intended as shows in the Plugin Manager:
I hope this helps.
Yeah im getting the same messages, have the lates version but it says(legacy) but its not and not usable anymore.
Ok, checked my installation and I realise I had to change the file structure. The plugin relies on the OBS plugin template scripts to package the windows files and this hasn't been updated for OBS 33 yet.
Anyway, a quick fix is to go to where the plugin is installed in ProgramData. The .dll file needs to be moved from the bin folder to the root plugin folder.
Move the file from:
C:\ProgramData\obs-studio\plugins\obs-plugin-countdown\bin\64bit\obs-plugin-countdown.dll
To:
C:\ProgramData\obs-studio\plugins\obs-plugin-countdown\obs-plugin-countdown.dll
Note: As I understand this works for version 33 and above of OBS. I think it will break older versions of OBS. I will wait for the plugin template updates before releasing a new version of it so that the correct structure is set but this will be for OBS 33+ only. For now this quick file move fix should get the plugin working and should remove the legacy tag from it on the plugin manager. This affects Windows and Linux versions of the app but not macOS.
For more details about the file and location changes you can see the OBS link here: https://obsproject.com/kb/legacy-plugin-developer-info
Hello, I used this plugin a while ago and am now reinstalling it. I followed all the steps correctly, but OBS isn't recognizing the plugin. I don't understand what's happening—please help!
What version of OBS are you using?
For OBS 33+ you need to install the OBS countdown folder in the program data folder and make this file change mentioned in my post here:
Post in thread 'Ashmanix Countdown Timer' https://obsproject.com/forum/threads/ashmanix-countdown-timer.160421/post-711285
It's a bit complicated for now as 33 breaks current plugin setups. I'm waiting for the plugin code to be updated to then update mines so you don't need to make the file changes.
