Status
Not open for further replies.
It's no longer synchronous with what is being requested of it, since your output queue is larger than the input queue - this never happened in any of my tests.
Alright. I also wanted to restate that CBR still isn't working properly, nor is filler data. Every time I hit a load screen my stream's bitrate plummets to 140 kb/s or something low. Sometimes if there is absolutely nothing going on it gets so low that I thing Twitch rejects the ingestion and my stream ends prematurely.
Yea, the encoding starts perfetly, image quality is good, then all of a sudden encoding stops...
This happens to me when i set Twitch preset, set GOP to 60 and disable CABAC.
So, messing with those two produces the probem for me. Maybe this will help you to narrow down the problem
Hello, I have a Fury X and can record just fine if I rescale output from my native 1440p to 1080p, but I can't record without rescaling at all. The "Start recording" button simply does nothing. Attached are my setting. What could be causing this?
Well, you're using a version so outdated that the advanced interface is still called the same as the simple one. You might want to upgrade. Like... 20 versions or so that you hit 1.3.0rc2.
Possibly just a bug in chrome then? I understand what most settings are for, just didn't bother with them as all I wanted was to compare this to OBS classic with VCE.
As of the recent... 5 or so builds, the Twitch preset sucks massive arse.
Example with the Twitch preset at 720p scaling + 60fps:
It was fine in one of the previous versions where you still had to setup everything in the advanced settings of the plugin, see here:
https://www.youtube.com/watch?v=71X7XdYXbr4
I've gone back to using x264 Superfast until this plugin is further along. It's very promising, I appreciate the work that @Xaymar is doing, and I'm going to be looking out for future updates. What I'm seeing currently at 720p60 is not what I'm looking for, though.
Thx for the plugin its awesome :D
I was wondering if u guys could recommend me a low quality, low size recording config for youtube.
I just need it to be viewable at 30fps, i dont need anything fancy.
The CBR with Filler Data bug is supposedly fixed in the next "driver package and will follow shortly". How shortly is shortly is up to AMD again.
VCE 3.0:
  • Tonga: Radeon R9 285, Radeon R9 380, Radeon R9 380X / Mobile Radeon R9 M390X / R9 M395 / R9 M395X / Radeon R9 M485X /
  • Tonga XT: FirePro W7100 / S7100X / S7150 / S7150 X2 /
  • Fiji: Radeon R9 Fury / R9 Fury X / R9 Nano / Radeon Pro Duo / FirePro S9300 / W7170M
  • Polaris: RX 460 / 470 / 480
so all this cards have this ''bug'' :p
rx 460 is polaris 11 tho, 470/480 polaris 10. not sure if the encoder on there, the rx 460 is different. I'm pondering if it will be worth upgrading to that for my stream pc, but probably not since i'll most likely buy the next "490" or whatever with hbm2/3.
On another note i noticed a lot of audio desync with quality preset on vbr peak constrained as opposed to when using speed or balanced preset. I couldnt sync it, kept changing.
Omg omg omg omg omg!
*Hyperventilates*
Any word on the stuck frame queue? My tournament is coming up soon, and it'd be a shame if I couldn't upload it in 1080@48 to YouTube!
I hope that 1.3.0rc3 reduces how often it happens, I still haven't been able to reproduce it completely stopping returning anything. :/
amd released a whql version last night, not sure if they only got the driver certified or added some new fixes tho.
Only contains remaining files and is WHQL certified. Already have it installed here.
Status
