Aitum Vertical
Aitum Vertical 1.6.7
Hi, I’m currently using the latest version of OBS and the latest Aitum Vertical plugin. I noticed in the release notes that it should be possible to “convert existing Aitum Vertical scenes to the new OBS canvas system.”
However, I cannot find any option in OBS or the Aitum plugin to make vertical scenes available in the main OBS canvas. I’ve already checked the Docks menu, plugin settings, and tried creating new scenes, but the feature doesn’t seem to show up.
Am I missing a step to enable this feature, or is it still experimental/only available under certain conditions? Any guidance would be really appreciated.
Thanks in advance!
Did you ever get a fix for this? Running into the issue myself.
Will there be a build supporting OBS 32.2.x for Ubuntu 26.04 LTS ? A few plugins appear to have a similar dependency issues and are requiring some updates to support the official OBS PPA release for the latest Ubuntu. ( https://obsproject.com/kb/linux-installation )
advanced-scene-switcher changes for reference are here ( https://github.com/WarmUpTill/SceneSwitcher/pull/1644/commits )
sudo apt install ./vertical-canvas-linux-gnu.deb
Note, selecting 'vertical-canvas' instead of './vertical-canvas-linux-gnu.deb'
Solving dependencies... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Unsatisfied dependencies:
 vertical-canvas : Depends: libqt6gui6t64 (>= 6.2.0) but it is not installable
                   Depends: libqt6widgets6t64 (>= 6.3.0) but it is not installable
Error: Unable to satisfy dependencies. Reached two conflicting assignments:
   1. vertical-canvas:amd64=1.6.4 is selected for install
   2. vertical-canvas:amd64 Depends libqt6gui6t64 (>= 6.2.0)
      but none of the choices are installable:
      [no choices]
Hello to the team!
Regarding Aitum Vertical Canvas, I experienced crashes due to an audio memory address issue.
I should point out that the crash occurs after several hours of streaming on average, 5 or even 7 hours in.
(Also posted in the Move Transition section).
I used Gemini to help me out:
Crash in audio-io thread during audio_wrapper_enum_all_sources execution (0xC0000005 Access Violation)
Summary:
OBS Studio crashes with an Access Violation (0xC0000005) in the audio-io thread. The crash originates from vertical-canvas.dll calling audio_wrapper_enum_all_sources, which triggers an active source tree traversal (obs_source_enum_active_tree) that intersects with move-transition.dll.
Crash Details:
  • Exception Code: 0xC0000005 (EXCEPTION_ACCESS_VIOLATION)
  • Fault Thread: audio-io
  • Primary Module: vertical-canvas.dll
  • Interacting Module: move-transition.dll
Call Stack Overview:
1. vertical-canvas.dll ! audio_wrapper_enum_all_sources
2. obs.dll ! obs_source_enum_active_tree
3. move-transition.dll ! move_enum_active_sources
4. obs.dll ! enum_source_active_tree_callback --> Access Violation (0xC0000005)
Technical Analysis:
  • Root Cause: A race condition occurs when vertical-canvas.dll enumerates sources on the audio-io thread while move-transition.dll intercepts active sources via move_enum_active_sources.
  • Issue Description: During obs_source_enum_active_tree, an active source pointer appears to be modified or freed concurrently by another thread, causing enum_source_active_tree_callback to reference invalid memory.
Expected Behavior:
Source enumeration performed by audio_wrapper_enum_all_sources on background/audio threads should safely lock shared source trees or handle potential concurrent modifications to avoid memory access violations.
Hi all! I was wondering how can I use Aitum to connect to Websocket?
My situation is I want to stream to one platform using Aitum with Websocket. AND at same time to Twitch under my normal information.
I can't seem to find a way to do both at same time. Or just finding out how to Websocket to Aitum
1.6.6 still is built with something amiss for ubuntu 26.04. It forces uninstallation of obs-studio and all properly built and working plugins.
The latest version is not compatible with Ubuntu 26.04 LTS. It would force removal of obs-studio from the official PPS and all the other plugins that are compatible and working resulting in quite a mess.
I've been running this plugin for a few months now through multiple versions up to 1.6.8 currently. One issue I keep having is that, though the dock shows my vertical canvas is streaming, it often is not actually streaming. The only fix (not really a fix) I have found is to stop and restart the vertical canvas stream multiple times until it actually starts to push the stream. I have both the latest OBS and latest vertical canvas plugin. Any ideas? TIA
That's what I'm saying. The dock shows the stream connects and starts streaming but not thing actually starts streaming on YouTube. I wait a while to see if the stream starts. Nothing. I stop and restart the stream from the vertical canvas dock. Nothing. I repeat a couple more times and the stream actually begins on YouTube. In YouTube studio no streams are shown for the first few times the plugin shows as streaming.
I assume it's not something I can resolve then, as I have reset my key multiple times over the past few weeks to try to resolve the issue and the results are the same. Also, the keys I have used are working fine with other plugins. But, thank you for having a look.
