Aitum Stream Suite
Aitum Stream Suite 1.2.5
Con obs studio 33.0.0 instalado, instalo aitum multistream suite 1.2.4 y me da un error de crash todo el rato, en modo seguro se ejecuta correctamente obs, y si desistalo aitum suite también. aitum multistream normal y vertical me funcionaban bien.
los fallos por lo visto vienen de por aquí
aitum-stream-suite.dll!load_cef → aitum-stream-suite.dll!load_browser_panels → libcef.dll → cierre de OBS.
aitum-stream-suite.dll y libcef.dll load_cef
según el texto del crash son los errores que reporta, pero ni idea de que son o como solucionarlo, supongo que hara falta una actualización.
Hi Aitum team,
Since today OBS crashes on every startup while Aitum Stream Suite is enabled. It worked perfectly during my stream earlier today (live from ~14:00 to 15:18, clean shutdown at 15:22). The very next launch (16:02) started a crash loop, and nothing was updated in between: same OBS, plugin, and GPU driver versions.
Setup:
- OBS Studio 33.0.3 (64-bit), Qt 6.11.1, obs-browser 2.27.6 / CEF 150.0.7871.287
- Aitum Stream Suite 1.2.6 (C:\ProgramData\obs-studio\plugins)
- Windows 11 build 26300 (26H2), AMD Ryzen 7 5700X, NVIDIA driver 32.0.16.1088
- Vertical canvas 1080x1920 + Twitch output configured in Stream Suite
Crash (access violation c0000005) on the main thread, always in the same place:
obs-browser.dll!QCefWidgetInternal::Init -> qt6core / qt6widgets event loop -> obs64.exe!run_program
So it looks like one of the Stream Suite browser panels being created at startup.
Latest crash report: https://obsproject.com/logs/crashes/GB9nliBUu7rn4iHj
What I already tried:
- Safe Mode: OBS opens fine
- Aitum Stream Suite disabled in the Plugin Manager: OBS opens fine
- Stream Suite re-enabled: crashes again
- Removed my only custom browser dock, disconnected my YouTube account, disabled browser source hardware acceleration
- Cleared the CEF cache (renamed plugin_config/obs-browser)
- Disabled Advanced Scene Switcher (it was only adding a startup dialog on top of the crash)
- Paused Norton 360 (its aswhook.dll is injected into OBS)
- Reinstalled the plugin
Side issue that may be worth fixing: when OBS is launched once without Stream Suite (Safe Mode or plugin disabled) and then closed, the scene collection is saved with the position and scale of every item in the vertical scenes reset to 0, and the Move transition removed. I had to restore Gaming.json from a backup several times.
Is there a way to stop the browser panels from loading at startup, or a fix planned? I can test a debug build or provide more logs.
Update: downgrading to 1.2.5 fixed it — OBS starts normally with the same config. So this looks like a regression in 1.2.6.
Update: found the cause and a workaround.
It wasn't the browser hardware acceleration, YouTube account, Advanced Scene Switcher, Norton, camera or update dialog. Those only changed the timing of the crash.
The cause was the dock layout that Stream Suite saved in the profile's aitum.json during my stream. From then on, every launch crashed while Stream Suite restored its browser docks (QCefWidgetInternal::Init). Even a clean reinstall of OBS + Stream Suite crashed from the second launch on.
Workaround: with OBS closed, remove the saved layout keys from basic/profiles/<profile>/aitum.json:
- dock_state_* (including dock_state_mode)
- stats_state_*
- canvas_split_* and panel_split_* inside each canvas
After that, OBS 33.0.3 + Stream Suite 1.2.6 start normally again, with all outputs and the vertical canvas intact. I've closed and reopened OBS several times since then with no crash.
