I'm striking an issue between your plugin and the atkAudio plugins Midi Control (another awesome plugin like yours).
That control is mapping my controls to OBS hotkeys via targetUuid which now seems to be changing for your macros that are being registered as hotkeys. They change when I restart OBS or switch scene. This means I need to re-map 8 controls every time one of these events happens.
For instance for "targetName": "Unpause macro ToggleMedia1Mute",
the targetUuid changes from
"targetUuid": "obs_hotkey:frontend:macro_unpause_hotkey_8",
to "targetUuid": "obs_hotkey:frontend:macro_unpause_hotkey_14", when changing scene collection and back
to "targetUuid": "obs_hotkey:frontend:macro_unpause_hotkey_2", when closing and re-opening OBS
I didn't notice this earlier so has something changed?
regards,
David
This has always been the case for those types of hotkeys.
A build with stable hotkey ids for the pause functionality will be available here in a few minutes:
Or alternatively here if you don't have a GitHub account:
Let me know if that works for you!
That works, thank you.
Thanks @kaaroux for your suggestions!
A build with the option to check if a mouse button is held down is available here:
Or if you don't have a GitHub account here:
Not sure about the stylus part though as I can't test it, but I will try to look into it when I find the time to!
Hello everyone,
I have a request. I noticed that version 1.32 made Advanced Scene Switcher work with Aitum Vertical. Is it possible to make it work with SE.Live as well?
Here's my specific issue: I currently have a soundboard/mixamp (Rodecaster Duo) with MIDI controls. I used advanced scene switcher to show the visibility of a scene source, wait 3 seconds, and hide the visibility of the scene source so I only have to press the MIDI button once. However, I still have to tab out of the game I'm playing in order to manually show the scene, wait 3s, and hide the scene for the vertical stream. I would like this MIDI button to run the macro for the vertical scene as well, but it seems like installing Aitum is the only way to accomplish this. However, I prefer to use SE.Live because of the smoothness of going live without needing a new stream key from TikTok every single stream. Seems like Aitum is better in a lot of ways, but I'm trying to automate more workflow, not manually type in stream titles and whatnot EVERY single stream. Anyways, Aitum vs. SE.Live aside, I would REALLY appreciate the ability to accomplish this. It seems like Advanced Scene Switcher can recognize the Vertical SE.Live canvas, but once you go to select a scene, "current scene" is the only option. Even if you select current scene, it won't let me select any of the sources within the scene, even if you delete all but one of your scenes. So is Advanced Scene Switcher / SE.Live compatibility coming soon? It would be GREATLY appreciated if so.
Hello everyone,
Unfortunately, I am not sure if SE.Live offers the same API functionality as Aitum Vertical.
If you have any info that would be much appreciated! :)
Does this plugin work with a MacOs M5 max Mac Studio ?
I think it should do.
But since I don't have a Mac and am only testing in a VM I can't confirm.
If you face any issues or need support just let me know! :)
I just wrote SE.Live a ticket request. I requested information on API, which I don't know much about. So I told them how to find this forum in hopes they'll reach out to you themselves. If not, hopefully they'll give me enough information on API's that I can middleman the information back to you.... I just hope it's easy to understand if that's the case because I don't really know what/how API's work. I just want to stream, man. Thank you for your quick response though. Hope you are having a wonderful day!
Is there a one button solution to temporarily disable Automatic Scene Switcher? Or at least to stop all switching when I've selected a particular scene?
Assuming you are asking about the Advanced Scene Switcher and not the built-in Automatic Scene Switcher plugin there are many ways to achieve this.
To name a few:
  • Use the dock to start / stop the plugin:
  • Set up a hotkey to start / stop the plugin:
  • Set up macro to stop the plugin when a certain scene is active:
  • Pause macros when a given scene is active (and optionally un-pause them otherwise)
Let me if you need help setting this up!
I ended up trying this and it seems to work for preventing switching (for four hours):
I will try your third option as well, as it looks to be the best way.
Do I need to add a command to my other scenes to restart Advance Scene Switcher after switching back?
That only works if you keep the "Run in parallel" box cleared for ALL macros, not just this one. That's a useful thing to have, so I'd shy away from making it unavailable.
If Adv. SS is not running, how would it run that command?
Another idea, if you don't have too many macros, is to put an AND NOT <poison scene> at the end of all of your conditions. (except those that are looking for a different scene specifically; if that succeeds, then of course it's not the other, so you don't need it then)
What I'm not clear about is if a macro has a command to shut down Advanced Scene Switcher, then it stays off until I manually start it?
I think I'll stick with my 4 hour 'wait' command. It seems to work without disrupting my other scenes. Before that, my Clean Desktop scene would get stuck in a break loop after 20 mins.
That's my understanding.
Seems like there has to be a better solution, but there's not enough detail here to find it. What's the Clean Desktop scene? And what's the break loop?
But, given that a 4-hour complete kill is okay, I assume that you're done at that point? So you'd close OBS before the 4 hours? In that case, you *could* stop it entirely on that scene, and set it to always start when OBS starts. I'd still do it differently though, just in case you realize after you're there that you ended it prematurely, and need a quick recovery. Neither a complete stop nor the 4-hour wait can do that.
I only need the Clean Desktop (source desktop with no banners or graphics) scene for a couple hours. After that, I switch back to the VLC and resume the breaks (station ID/bumpers) by switching scenes.
So this is a 24/7 stream? With 3 scenes total? Bounce between two of them automatically until you manually take the third, stay there indefinitely, then resume the other two?
In *that* case, I'd have just two macros:
  • If Scene A for X time, switch to Scene B
  • If Scene B for Y time, switch to Scene A
Done!
Resume the loop by taking either A or B. If you're on any other, nothing happens. Adjust the triggers as needed, like for the end of playback instead of time, or whatever, but keep the same structure.
Normally, it's 24/7 streaming from VLC media source with timed breaks/bumpers/IDs. But sometimes I take it offline to do screen recording and I don't want interruptions from the IDs/bumpers.
I just didn't feel comfortable with a macro that shuts off the scene switcher. The four hour delay macro seems to work well, since I don't anticipate screen recording more than 4 hours.
