What would autogenerate that function?
When you select a path which does not yet exist and click the "Open" button the file will be populated with the auto generated code.
Also my IDE (VS Code) does not recognize obspython. Can you tell me how to make that one known?
I believe this file can be found in the obs-scripting directory.
So, for example:
C:\Program Files\obs-studio\data\obs-scripting\64bit\obspython.py
Under "Configure Video" for a Video Capture Device source (capture card) there's "SIGNAL STATUS"
Is there a way to use this in a macro to make the Advanced Scene Switcher do things when this changes? It seems my capture card always outputs the "NO SIGNAL" image, so the typical "has no output" etc conditions don't work.
View attachment 116324View attachment 116325
Unfortunately, I don't think there is away to access this information via the OBS API.
So, unless this information is available to the advanced scene switcher via some other way I don't think you can use it in your macros.
  • Like
Reactions: vzx
Sweet adds! I immediately jumped on those OBS preview actions. It seems like the Disable preview is a little wonky for me, though. If I disable through the action, I can't re-enable using the Enable preview action (which also renders Toggle preview a "disable only"). I also have to click Enable Preview on the OBS window twice in order for the preview to show back up.
Triggering the preview enable/disable via the frontend hotkey does not share this behavior.
Also, it looks like the images on this post are private.
Thanks for this amazing plugin!
With the 1.32.0 update, I can no longer select scenes on Linux (flatpak). The drop-down menu is empty. I am on Linux Mint 22.1.
Downgrading to 1.31.0 makes it work again.
Love the updates! Absolutely fantastic!
One/Two quick questions/requests. Can the variables be dockable, able to be opened in a separate window so that the macros can be seen side by side with the variables? - And for icing on the cake, could a search/filter top entry field be added to filter the variables displayed?
Thank you, as always!
Ah right ... I remember now why I didn't want to merge those changes ... :D
Unfortunately, that is a bug in the OBS API.
I raised a PR to fix it on OBS side:
The fix was approved but not yet merged into an official OBS release.
So, this issue will be resolved once the behavior is fixed on OBS side.
Sorry about that!
Sorry about that - I will look into it.
At the moment that is not possible, but I will add it to the list of things to do.
Thanks for the suggestion!
I was able to identify the issue and it should be fixed with the latest release.
Just to be sure, can you please confirm, if everything now works as expected on your side, too?
Been having a bit of a bug with setting variables from macro properties. It works as intended when first set up, but it seems that every time I relaunch OBS, the property selection is cleared every time. I end up having to reselect the correct property for every variable that uses that method, which is incredibly tedious.
In my case, specifically, I am setting variables to the width and height of specific sources, as seen below:
Whenever I relaunch OBS, it appears like below:
I have multiple instances like this throughout various macros. Exporting and reimporting settings don't solve the issue.
On a separate subject, any possibility for triggers to be added for Media state conditions such as "next" and "previous"? In my current setup, the Media state "ended" condition is used to trigger actions when videos in a VLC playlist end. This works perfectly fine until I want to manually press "next" or "previous" as those actions don't have any condition triggers associated with them. Is this functionality you have ability to look into on your end, or is that entirely a OBS/VLC caused restriction?
Sorry about that and thanks for letting me know about the problem!
I think I was able to track down the problem and will release yet another update shortly.
Please let me know this new version resolves the issue on your side! :)
Unfortunately, I believe there is no direct "next" / "previous" signal.
But I will have another look once I find the time to.
This plugin's been broken for me since OBS 32, and today I tried to update it but now OBS 32.0.2 crashes on every launch until I remove the scene switcher. Is there any way I can find and remove my scene data as well and start it fresh and maybe import my old backups? I have a ton of scripts I've built over the years and am worried they are all basically gone now.
Can you share a crash log and OBS log?
Which version of the plug-in are you using?
Backups should automatically created if the version you are using is not too old:
This wiki page also describes where your settings are stored.
Hi! I just tried the plugin version 1.32.2 on my OBS 32.0.1
Macro which should send a message in twitch chat doesn't work (timestamp issue or something like that). Macro which hides a source works.
OBS cannot be closed normally, window is not responding after the close command.
I switched back to 1.31.0
Hi! First of all, FANTASTIC piece of plugin. I can't overstate how much it has made my life easier!
I am getting into the variables system. I do use a variables system through Touch Portal ( ElGato StreamDesk's alternative on your Android device) and I can't find a way to inter-connect the variables of them both so as to have a better control over OBS.
There are things that I need to run through Touch Portal as I have a quide in-depth system already running over there, but I also need the controll given by variables within Scene Switcher.
Any idea on how could i made them talk? I don't mind if I need some janky solution, as far as it works!
Thanks for letting me know.
Would you mind sharing more details about what you are referring to regarding timestamp issues?
Can you share an OBS log, if you still have one of that issue?
Yep. We had a short conversation about 6 months ago. I encontered a similar issue, you said it was a timestamp. I downloaded some very special version of the plugin and the problem disappeared. Everything was ok after updating to 1.31.0
This is the log when I expected a chat message in 1.32.2
22:35:55.482: [adv-ss] try to sleep for 300
22:35:55.784: [adv-ss] condition twitch returned 0
22:35:55.784: [adv-ss] Macro Reward returned 0
22:35:55.784: [adv-ss] Macro Chat returned 0
22:35:55.784: [adv-ss] Macro New Follower returned 0
22:35:55.784: [adv-ss] Macro Raid returned 0
22:35:55.784: [adv-ss] Macro Show follower alert returned 0
22:35:55.784: [adv-ss] Macro Listen for followers is paused
22:35:55.784: [adv-ss] Macro Listen for followers returned 0
22:35:55.784: [adv-ss] Macro Start returned 0
22:35:55.784: [adv-ss] Macro End returned 0
22:35:55.784: [adv-ss] try to sleep for 300
By some reason OBS is not creating a crash report, but the new log starts from
22:47:41.682: Crash or unclean shutdown detected
22:47:42.946: [Safe Mode] Normal launch selected, loading third-party plugins is enabled
Thanks, that fixed it!
