Good evening guys, hope everyone is doing well!
I just installed Advanced Scene Switcher and it's working fine, however I can't seem to figure out the following:
I am streaming League of Legends, which consists of 2 windows: League Client and League Client (Ingame).
My idea was to do a scene transition automatically like this:
League Client Closes -> proceed on Scene Transition -> Open League Client (Ingame).
I managed to achieve this in the macro section, but I don't know how to make it automatic, cause right now I have to press a button in order to start it.
Any help is appreciated!
Display Image File Name from Image Slideshow - Possible in Advanced Scene Switcher?​
Trying to find a way to display the file name of the image that is currently being shown from within an 'Image Slideshow' source. The idea would be that as the image changes in the slideshow, the file name would change to that of the new image also.
Hoping to get this to work for an image slideshow that is pulling from a directory, rather than a static list of images entered into the 'Image Files' field, which I believe complicates obtaining the file name of the current image being displayed.
Not sure if it is possible, but was curious if there is a way for Advance Scene Switcher to perform this type of function. If so, I would greatly appreciate any insight as to how to best go about implementing this. Thanks for any help in advance!
While this should already be possible with the current version by using the "Slide Show" condition type it should be a lot easier in the following test build:
It adds the option to directly query the file name of an image slide show and adds support for the "slideshow_v2" source type.
Unfortunately, you will have to be logged into GitHub to be able to download this build.
Let me know if that should be a problem for you.
When you are using this build you should be able to achieve what you are looking for by setting up a macro similar to this example:
It boils down to "if the currently displayed slide of the source "Image Slide Show" changed assign the file name of the file being displayed to the variable "Slide Show File" and set the "Text" settings value of the "Text(GDI+)" source to the value of that variable".
Let me know if you run into any issues with that build or if you have any questions!
Hope this helped! :)
If you want to automate the detection of the "League Client Closes" scenario I would recommend to use either the "Process" or the "Window" condition type.
OBS is not generating a crash log, but I have been wotking on a long macro, and I start/stop adv-ss from time to time when I notice errors I need to fix. Lately after 3-4 stops, it'll hang/freeze (keeps playing, but only whatever was happening at the time of the freeze, just saying its not like a "pause" freeze, but an "animated" freeze, no buttons work but things continue playing, except audio, hope that makes sense) OBS but not technically crash, but it never recovers and you have to kill OBS with Task Manager.
Responded on GitHub, but wanted to respond here as well for completeness also. Please feel free to respond to whichever you prefer, no need to keep both going.
"Thanks so much for your reply! Incredibly helpful! I mostly have been able to replicate your example, however am running into an issue when it comes to selecting for the 'Action Type' in the 'Variable' section. Under 'Variable' > 'Set to macro property' > 'Slide Show File' > '--sele...' I am unable to access any action types in the dropdown or being able to write anything in this field.
I did try to implement the build you shared, but I am unsure that I properly integrated, as it seems like this may be the cause of the issue. Please let me know if that is the case or if you believe there is another way I could go about resolving. Appreciate the assistance again!
My replicated example below for reference:"
Thanks for reporting the issue!
Can you export your settings to a file and share them with me?
Then I will try to replicate the setting on my side.
I have like 10 things I need to make duck audio on multiple sources, thats really involved with filters, it seems, I was wondering id theres an easier way to make like 3 sources duck if anything in sceneN plays?
sorry for my spelling, I caught the betes, and its taking my vision lately, need to see an eye doc.
Two consecutive hotkeys aren't running correctly. I'm on Windows 10 using Ashmanix Countdown Timer.
My macro:
If streaming is running and current scene is Starting Soon
hotkeys - frontend - Set the timer
hotkeys - frontend - Start the timer
I could make a workaround, but doesn't work if I'm on the "Starting Soon" scene.
If streaming is running and not current scene is Starting Soon,
Switch scene to Starting Soon
I tried with another (unchecked) macro between the hotkeys: if not current scene is Starting Soon, switch scene to Starting Soon. Still breaks.
In this case, the two hotkeys are of same plugin. They are being pressed simultaneously. Rather, expected behavior is execute one key, then execute another. Not at the same time.
An option like "Wait until this hotkey is pressed" would solve the problem.
My macro:
Can you elaborate on what exactly breaks? (Unfortunately I am not familiar with the Timer plugin you mentioned)
Have you considered adding a "Wait" action between the two hotkey presses?
I don't think implementing a "wait until hotkey is pressed" option is feasible, if I am understanding what you are trying to do correctly.
(I assume you mean something like "wait until the actions to be performed by the hotkey press are completed")
This would require the plugin to interpret what each OBS hotkey is intended to do and then check if that process is completed.
Adding to what Warmuptill said, emulated hotkeys are not even pressed and released (2 events) like you'd imagine from a physical keyboard. They're each a single event, at a single instant in time. With no Wait in between, and with no way to know what the effect is and when it's done or not, consecutive hotkeys *are* effectively simultaneous, along with the first non-hotkey action that follows.
Two hotkeys of same plugin pressed at the same time, does nothing. It's like pause + start at the same time. Timer plugin does nothing.
Whoa, this solved my problem.
Correct
Seems a lot of work. "Wait" function does the job right now.
I am brand new to advanced scene switcher. I have three scenes that I want to switch automatically to a timer when I’m streaming or recording.
—Every 7 minutes I want a “scene A” to switch to “scene B” and every 7 mins switch “scene B to “scene C.” Then have “scene C” switch back to “scene A” and repeat/loop until end of recording/stream—
How do I do this? I need picture instructions because I can not!
Use lots of macros! One for each step:
  • Step 1
    • Condition:
      • Scene _ for A seconds
    • Action:
      • Switch to Scene 1
  • Step 2
    • Condition:
      • Scene 1 for B seconds
    • Action:
      • Switch to Scene 2
  • Step 3
    • Condition:
      • Scene 2 for C seconds
    • Action:
      • Switch to Scene 3
  • Step _
    • Condition:
      • Scene [_-1] for ? seconds
    • Action:
      • Switch to Scene _
Looping is easy, just by having the last one create the condition that the first one is looking for.
I didn't do *exactly* as you asked, so I could show you a better way still, of doing videos. Regardless of length, this video will transition right at the end, using the last 1/2-second for a 1/2-second transition.
And I made this one loop too, using the same method as the text version above.
I also like to set the scan interval as short as it goes. "Check conditions every" 50ms. Or if it goes faster now, do that. The difference is in the accuracy of the 1/2-second at the end of a video, as I've shown here, and it gives better responsiveness overall anyway. The tradeoff is slightly higher CPU usage, which I don't notice at all on my rig.
If you're using that setting to intentionally slow down some logic, that's generally not a good programming style...
This is how I am going about the ducking so far, it seems to work for the most part, seems longer files arnt ducked the whole time...
I have a couple more condition sources, and a few more action sources to put in...
Just curious if you think I am on the right track, or a better way I could be doing it?
Does your response here still stand?:
My suggestions still do.
Seems to me like you're trying to reinvent a common professional tool...while claiming that the same tool is "too hard".
  • Step 1
    • Condition:
    • Action:
      • Switch to Scene 1
  • Step 2
    • Condition:
    • Action:
      • Switch to Scene 2
  • Step 3
    • Condition:
    • Action:
      • Switch to Scene 3
  • Step _
    • Condition:
    • Action:
      • Switch to Scene _
Hey Aaron! Thanks for getting back to me with help!
I noticed that our macro actions are slightly different here. Is it good?
Also is everything on my general tab okay?
Qi’s that need some A’s
1) I have two scene collections (recording and live-streaming). I have made macro rules for the recording. If I make a new set for the livestream will there be any issues? Or does the macro only work when the scenes are available in the selected collection?
2) What if I need to step away for my live stream and set it to a different scene that isn’t on the macro. Will it simply continue or will it continue when I click back on a scene that is in the macro?
3) Does the Advanced Scene Switcher only start when I press start recording or start streaming?
Thank you so much ‍♀️
I'm still using an older version. That might be the difference. Think through what it says and what that means. Seeing the other choices for that setting, and thinking through what *they* mean, may also help to understand *that* choice.
Looks good to me, except for the scan interval. 300ms is slow enough to see, if you pay attention to it. Like I said, I like to set mine as fast it it will go, which for me is 50ms. You can't see that.
All of Adv. SS settings are in the Scene Collection. So if you load a new Collection, you get a whole different set of settings and macros.
Each macro runs independently. If it's looking for Scene X for Y seconds, and you switch away from Scene X before that, then the condition never becomes true.
In fact, that's how you escape this sequence: just switch to something else, and the next step is not triggered. If you did it with a single macro and an alternating chain of Switches and Waits, then the Wait would keep running, and the next Switch would happen anyway. So I don't like the single-macro method with Waits.
That's a setting towards the top of the General tab. I set mine to always be running all the time. Sometimes that causes some macros to run unexpectedly when I'm still working on them, but by the time I go live, they're all worked out so they won't.
And, always-running allows you to do other things too, like start recording or streaming at a given time or by some some other trigger.
Also, I see that you're looking for the "Recording - Split" scene "For exactly" 6 minutes. Looking for something exact is usually a "bug magnet". A classic example from the larger world of programming might be:
C-like:
while(<something>)
    print_line(x);
    if (x == 5)
        print_line("x is 5!");
    //do other stuff
And the printout might be:
0
1
3
4
6
8
9
Notice there's no 5, and the special announcement didn't happen.
It's much more reliable to look for a threshold instead of an exact value. In your case, that would be "For at least" instead of "For exactly".
And use the "only on change" checkbox to keep that from repeating. In fact, I have that box checked for *all* of my macros, whether they need it or not.
Heh, I did forget that I posted about this, my settings got corrupted and I have been restoring what I lost, and now getting back to the ducking finally. but since then Ive also discovered, i believe having a Beacn accessory renders the filter option useless. So if I want ducking, it has to be via adv-ss.
Right now if I set a compressor filter to ducking,, it ducks AFTER the played file and nobody on obs discord seems to know why, or they are just ignoring me... but they are usually pretty helpful if they know the answer. they keep personal opinions and comments out of their replies. They just help when they can, and stone cold ignore you when they cant. I used to find it rude, but I am coming around to it suddenly...
Video (warning, audio is loud) of how compressor ducking works for me
Unlike a lot of the users on here just asking you to write a macro for them, I'm trying to learn, showing my work and asking for advice, not if I should be doing it this way but if I'm on the right track, is this how you would do it? with adv-ss specifically, because we are in the adv-ss forum, not the compressor forum, not some other 3rd party whatever the hell forum, just adv-ss.
So stick to the adage, don't have something nice to say, don't say anything at all please. Its not your plugin, don't feel compelled to reply to every post... think of this as a discord extension, chime in with useful answers, stay stone cold silent if you don't, nobody wants to read your negativity about their ideas.
