Bug Report 2 Cards In System: Can't Select Card
Hey
I have two cards in my System, they seem to be both found by obs, but i can't select the card for rendering in the settings.
the selected card is also hopping.
please find log an screenshot attached
  • 2016-07-13 08-50-33.txt
okay thanks. is it planned/scheduled?
Changing cards is not a solution (first card is x16 slot 2nd x4) but it seems i can "control" is switching the monitors of the card i wont use off.
so im i right that scene rendering will be done on selected card (selected in log)?
my plan is tu use the low gt 710 for scene rendering and the gtx970 for gaming
Bad decision. Better forget about gt 710. SLI require Multi-adapter compatibility option enabled at 'Game Capture' - and this is slow method. gtx970 - is good enough to take care of both obs and game itself (picture from a game not goes to the gtx970 copy>ram>upload to gt 710>gt 710 obs processing>ram>cpu encode; it simply goes: internal gtx970 copy & obs processing>ram>cpu encode).
08:52:10.458: ┃ ┣download_frame: min=0 ms, median=17.411 ms, max=47.752 ms, 99th percentile=27.24 ms
Considering that having a second card in your system causes both cards to operate in pci-e x8 mode (or lower), having the second card is actually contributing to the problem rather than solving it.
Okay i removed the 2nd card.
bevore bying it i had a pcix1 sound card. i also removed it, so you were right.
my gtx970 ran in pcix8 mode and that caused all lags.
everythings nice now.
Thanks for the help i totally forgot the lanes thing.
