100% GPU usage only when minimizing obs with replay buffer on.
Dabrownie
im running obs in portable mode with the launch parameters "--portable --startreplaybuffer --disable-shutdown-check --minimize-to-tray". as soon as obs is minimized to the taskbar or the tray, obs uses 100% gpu. obs uses 15% gpu when not minimized. ive tried disabling HAGS, tried all monitors on 60hz, tried setting obs to power saving, i am on nvidia game ready driver 595.71, latest bios for my mobo, latest chipset driver for 9800x3d. latest obs update. ive tried starting fresh obs install and settings, same issue.
Specs if it matters:
RTX 4080
9800X3D
32GB DDR5 6000 CL30
ASUS ROG X670E-F
